02-26-2021 07:27 AM - edited 02-26-2021 07:29 AM
I have a connection between a Cisco c500 and a Cisco 3560 in trunk on a vlan (vlan id 216). When one of the 2 switches is accidentally restarted following an electrical outage, the "switchport mode access" command is added to the trunk port, removing the "switchport mode trunk" command so the switch is no longer reachable.
This is the example:
Switch 1
cdp
Device ID: PB_C500_CET2
Entry address (es):
IP address: 10.20.16.59
Platform: cisco WS-CE500G-12TC, Capabilities: IGMP switch
Interface: GigabitEthernet0 / 1, Port ID (outgoing port): GigabitEthernet12
Holdtime: 171 sec
Version:
Cisco IOS Software, CE500 Software (CE500-LANBASE-M), Version 12.2 (25) SEG6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 05-Sep-08 20:31 by myl
advertisement version: 2
VTP Management Domain: 'Piombino'
Native VLAN: 1 (Mismatch)
Duplex: full
Management address (es):
Switch n1 is configured as follows:
interface Vlan1
no ip address
shutdown
interface Vlan216
description *** SWITCH MANAGEMENT ***
ip address 10.20.16.92 255.255.252.0
ip helper-address 10.20.1.1
ip helper-address 10.72.4.20
interface GigabitEthernet0 / 1
description *** Link to C500 CET2 ***
switchport trunk native vlan 216
Switch2 before reboot:
interface GigabitEthernet0 / 12
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan216
ip address 10.20.16.59 255.255.252.0
no ip route-cache
Switch2 after reboot:
Current configuration: 295 bytes
! THIS FILE HAS BEEN GENERATED BY THE GUI.
! ANY CHANGES TO THIS FILE MAY RESULT IN INCORRECT SWITCH BEHAVIOR.
interface GigabitEthernet12
description Link to 3560 CET2
macro description cisco-other
ip dhcp snooping trust
end
! F16C
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan216
no ip route-cache
This problem happens often. Please help me. Thank you
Solved! Go to Solution.
02-26-2021 07:54 AM - edited 02-26-2021 07:55 AM
make sure you write and save the config after changes.
Try defaul the interface and remove the macro and configure again and test it, make sure you write and commit the changes.
no macro description cisco-other
end
end
03-02-2021 12:37 AM
Thanks for your help.
I always did wr whenever I changed the configuration of the C500.
I considered your advice to remove the macro.
Now I'm testing the switch.
I hope I have solved the problem. Thank you
03-02-2021 02:09 AM
Glad all went to well, thank you for marking as a solution (which helps other community members to review if they have the same issue - easy to resolve by themself).
02-26-2021 07:57 AM
You also have a native VLAN mismatch on the trunk between switches, you want to fix that as well.
02-26-2021 11:17 AM
reboot without save the running-config make SW use start-config and make the trunk go to access BUT
the VLAN info is save in other memory location and it not change with running-config.
