01-20-2019 05:40 AM - edited 01-25-2019 07:01 PM
I own a Cisco rv 325, and i am trying to install a certificate from comodo that i bought.
Been googling and all the tutorials that i found are older firmware that dont look at all the one i have,
I am running the lates versjon.
The file i need to import must be in a singel file, i dont understand what file needs contain. Key, Priv Certificate and CA Bundle.
WHat order and how it works.
I have tryed and failed many times.
Best Regards
Michel
Solved! Go to Solution.
01-25-2019 06:53 PM - edited 01-25-2019 06:57 PM
I finaly figured it out.
You need to make .ca bundel.crt containing the certificate first then add the the ca bundle file, you dont need the private key.
Remember not to add any new lines btw certificate and ca bundle.
It worked for me.
The nice guys from ssls.com helped me :)
It would have been nice to see any info this the help section on the router. Not everybody are experts on cisco and ssl.
Best Regards
Michel
01-20-2019 06:19 AM - edited 01-25-2019 07:03 PM
I deleted this post because it contained duplicate information.
It worked for me.
Best Regards
Michel
