11-19-2020 06:18 AM - edited 11-19-2020 06:19 AM
Hello! I have 2 computers, 2 vlan, and 1 cisco sg-250
I do the initial setup, create vlan 101, interface 192.168.101.1 255.255.255.0
Then I set up two computers
PC1 is connected to GigabitEthernet11
IP 192.168.101.2
MASK 255.255.255.0
Gateway 192.168.101.1
PC2 is connected to GigabitEthernet14
IP 192.168.101.3
MASK 255.255.255.0
PC1 has a shared folder, and now I can access it from PC2. Everything works!
Next, I create vlan 104, interface 192.168.104.1 255.255.255.0
I assign the GigabitEthernet14 port to this vlan
Changing network settings on PC2
IP 192.168.104.3
MASK 255.255.255.0
Gateway 192.168.104.1
I try to open a shared folder on PC1 and nothing comes out.
Ping 192.168.104.1 - Success
Ping 192.168.101.1 - Success
Ping 192.168.101.2 - Failure
#show running-config
switchb118c2#show running-config config-file-header switchb118c2 v2.5.5.47 / RTESLA2.5.5_930_364_286 CLI v1.0 file SSD indicator encrypted @ ssd-control-start ssd config ssd file passphrase control unrestricted no ssd file integrity control ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0 ! ! unit-type-control-start unit-type unit 1 network gi uplink none unit-type-control-end ! vlan database vlan 101,104 exit voice vlan oui-table add 0001e3 Siemens_AG_phone voice vlan oui-table add 00036b Cisco_phone voice vlan oui-table add 00096e Avaya voice vlan oui-table add 000fe2 H3C_Aolynk voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone voice vlan oui-table add 00d01e Pingtel_phone voice vlan oui-table add 00e075 Polycom/Veritel_phone voice vlan oui-table add 00e0bb 3Com_phone bonjour interface range vlan 1 hostname switchb118c2 username cisco password encrypted 78143518e5eqwcdd9da79ae58955f96b5f40040d privilege 15 ip ssh server ! interface vlan 1 ip address 192.168.1.254 255.255.255.0 no ip address dhcp ! interface vlan 101 name server ip address 192.168.101.1 255.255.255.0 ! interface vlan 104 ip address 192.168.104.1 255.255.255.0 ! interface GigabitEthernet11 switchport access vlan 101 switchport general pvid 101 switchport trunk native vlan 101 ! interface GigabitEthernet14 switchport access vlan 104 switchport general pvid 104 switchport trunk native vlan 104 ! exit
# show ip route
switchb118c2#show ip route Maximum Parallel Paths: 1 (1 after reset) IP Forwarding: enabled Codes: > - best, C - connected, S - static C 192.168.101.0/24 is directly connected, vlan 101 C 192.168.104.0/24 is directly connected, vlan 104
What am I doing wrong??? Why can't I get to the neighboring vlan 101 from vlan 104? Please help me figure it out.
11-19-2020 06:49 AM
Hello, i think the problem isn't your network. Its seems to be pc's firewall. Have you checked it?
11-19-2020 07:19 AM
Hi there,
Double-check if you have enabled Inter-VLAN routing IP Configuration-->IPv4 Interface-->IPv4 Routing -->Enable. The PC's firewall as Pessoa mentioned might be another reason for the inter-VLAN connectivity issues.
Martin
11-19-2020 10:27 AM
Martin, hello! Thanks for the answer.
I checked it again. Through the GUI, IP Configuration -> IPv4 Interface -> IPv4 Routing -> Enable, the checkbox is on.
Honestly, i don't understand where Firewall has to do with it. If everything works fine while in the same VLAN? As soon as I put the ports in different VLANs, the shared folder on PC1 becomes inaccessible.
