Cisco SG200 Data and Voice Vlans
Ben Rodriguez
Hello Support Community,
I'm trying to figure out how to configure the ports on a Cisco SG200-8P for data and voice vlan.
Whereas, the enterprise grade equipment offers command line and does not require any fiddling with GUI, I'd like to accomplish something simple as
interface GigabitEthernet0/1
switchport access vlan 30
switchport mode access
switchport voice vlan 25
Can someone show me the ropes on the SG200 to accomplish the same.
The article I found here leads to a deadend
Sujoy Paria
You can follow the below mentioned link (Chapter 14 [VLAN Management], page 177) onwards to configure the mentioned VLAN settings on the Switch port…
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/administration_guide/Cisco_200Sx_v1_4_AG.pdf
In case still you are facing any problem to configure the VLAN on the mentioned Switch then you can open a service request with us by contacting our CIN, you can get the contact number details for your region on the following link…
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
