CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
271
Highlighted
Beginner
Cisco SG300-28 VLANs can't reach internet except default vlan 1
Hi Members,
I have set an Sg300-28 Cisco in Router mode with the following config but only the interfaces on vlan 1 can reach internet.
Vlan 2 pinging to internet gateway 192.168.100.1 fails. I have tried up route but nothing works.
Any pointers will be appreciated.
Config;
switch3fdb71#sh running-config
config-file-header
switch3fdb71
v1.3.7.18 / R750_NIK_1_35_647_358
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
More: <space>, Quit: q or CTRL+Z, One line: <return>
bonjour interface range vlan 1
hostname switch3fdb71
interface vlan 1
ip address 192.168.100.77 255.255.255.0
no ip address dhcp
interface vlan 2
name tlan
ip address 192.168.7.1 255.255.255.0
interface gigabitethernet1
switchport mode access
interface gigabitethernet2
switchport access vlan 2
exit
ip default-gateway 192.168.100.1
8 REPLIES 8
Highlighted
VIP Mentor
Re: Cisco SG300-28 VLANs can't reach internet except default vlan 1
If the Device already setup in router mode.
you need route required as below :
ip route  0.0.0.0 0 0.0.0.0 192.168.100.1
Still have issue post complete config alonng with show ip route output.
BB
*** Rate All Helpful Responses ***
Highlighted
Beginner
Hi and thanks.
switch3fdb71#sh ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
S 0.0.0.0/0 [1/1] via 192.168.100.1, 00:01:42, vlan 1
C 192.168.100.0/24 is directly connected, vlan 1
switch3fdb71#
That's the IP route results after adding the IP route.
The config above is basic. Nothing more added from the default.
Highlighted
VIP Mentor
Ok you have route back entry for network  192.168.7.0/24 from 192.168.100.1
EDIT :
Please also confirm the device Configuired on  IP  192.168.7.X able to ping 192.168.7.1 ?
BB
Highlighted
Beginner
A PC on 192.168.7.2 can ping 192.168.7.1 and can also reach 192.168.100.77
Problem is it can't ping 192.168.100.1
How do I add a route on 192.168.100.1 which is a Huawei Onu device ?
I have tried adding a static route to 192.168.7.0 /24 without success. Which gateway should I add?
Highlighted
VIP Mentor
I have no idea about that product, Google may help you.
just did one quick search here is document to add static route not sure if that work for your model.
https://www.grandmetric.com/knowledge-base/design_and_configure/how-to-configure-static-routing-huawei/
BB
Highlighted
Beginner
Thanks for the pointer. I have googled about the cisco Sg-300 series and read a lot about it but it ain't a straight forward config as the catalyst.
I have created the static route back to 7.0/24 with different gateways (7.1,100.1,100.77) but nothing works.
I hope the gurus or Cisco employees in this forum can help crack this once and for all.
Highlighted
VIP Mentor
EDIT :
Sorry to hear that not work, please post all the screenshot cisco device and Huawei to understand
BB
Highlighted
Beginner
Sorry been away from the office. Will revert soonest.
