10-28-2013 04:12 AM
Greeting's, I would like to enable port security on a Cisco SG300 28P PoE Switch. I would like to know how this can be done in cases where port's are further connected to 8-port desktop switches and in cases where computers are directly connected to the switch.
Thanking you in anticipation,
Parth.
Solved! Go to Solution.
10-28-2013 04:31 AM
This is described in detail in section "Configuring Port Security" on pages 326 to 329 of the Cisco Small Business 300 Series Managed Switch Administration Guide document.
The difference between a port serving a desktop switch and one directly serving an endpoint is just the number of MAC addresses you'll want to allow.
Do you have any specific questions?
10-31-2013 06:52 AM
Here's 2 documents how to configure port security for dynamic and static.
https://supportforums.cisco.com/docs/DOC-27753
https://supportforums.cisco.com/docs/DOC-27720
-Tom
Please mark answered for helpful posts
10-28-2013 04:31 AM
10-31-2013 06:52 AM
-Tom
11-01-2013 05:32 AM
Thank you to both of you. I'm sorry for the spoon feeding i required. I'm sorry and shameful that I did not consult the guide first
11-01-2013 06:40 AM
Well i small exp. sharing here ..
i would not put a broadcast control cap on the very port where the 8 port switch is inteneded to be connected .
and ya never be sorry for learning ,its a life process
cheers!!!
