07-15-2021 07:40 AM
I am using the cisco SG350-10 in DHCP server mode with an IP camera and it sometimes work and sometimes not. When I connect the ethernet cable on ports 1, 8 and sometimes 6 I get the ACT LED blinking and I can connect the camera. If I try to connect to a different port I get no light on the ACT and I cannot connect at all.
The camera works when connected directly to my computer. I'm breaking my head but I cannot figure out what is going on here. Any suggestions?
Best,
00
Solved! Go to Solution.
07-28-2021 09:28 AM
- Ref : https://imenco.no/wp-content/uploads/2018/02/Goblin-Shark-User-Manual-Rev-16.pdf
Cameras pinned out with only 2 Ethernet pairs (4 wires) could encounter connection
problems when connected to Gigabit Ethernet switches. Appropriate settings must be
altered in the switches to accommodate for this.
This may refer to Auto-MDIX being recognized or not. I don't think the small business switch can be changed w.r.t supported behavior , you need higher level hardware and or IOS based switches for that , you may then test settings according to (for instance) :
M.
08-11-2021 05:41 AM
It works!!!
I set the speed to 100M and added MIDX from auto in the settings and both cameras work with the ports that they couldn't connect before!
Thank you Marce
07-16-2021 12:18 AM
- Compare port-settings for working and none-working ports, also check the logs and or compare between working and when a none-working connection is being made.
M.
07-20-2021 04:37 AM
I checked the port settings but they seem identical. Regarding the logs, when I connect/disconnect the Ethernet cable from a working port I immediately get some notifications but with the non-working ports it is like nothing is happening.
07-20-2021 05:25 AM
- Are the none-working ports operational for other devices (=not IP camera) ?
M.
07-20-2021 06:26 AM
Yes. I tried to connect the non working ports with my laptop as well and there are no problems with that.
07-20-2021 09:44 AM
- You may have a cable-length , problem. As a test use a very short lan-cable to connect the camera to the switch. Check if this resolves the issue or not.
M.
07-22-2021 11:40 PM
I've tried with a shorter cable and I still get similar behavior.
07-23-2021 12:26 AM
- Do the camera's require POE ?
M.
07-23-2021 05:19 AM
No, the cameras are powered from a supply.
07-23-2021 09:41 AM
- Do the cameras have some sort of power-ok-led-status-indicator ? Also what is the full model-name ?
M.
07-28-2021 06:46 AM
There is no LED status indicator for the cameras. The model is goblin shark from Imenco. Here you can find the product page.
07-28-2021 09:28 AM
M.
08-11-2021 05:41 AM
It works!!!
Thank you Marce
