Cisco SG350 Inter-VLAN routing
MikeWerner0426
I have a SG350-10MP, and want to know if this is possible without a external router (this is all based on everything living on one switch).
I have VLAN1 set up with a IP of 192.168.1.1/24 and DHCP with some addresses in that range
I have VLAN2 set up with a IP of 172.22.254.254/16 - no dhcp range
I have one device that needs to live in VLAN2 and have a IP in that range, but needs to communicate with another device in VLAN1. Is it possible to set up the IPv4 routing to make the 2 talk? And if it is, how would I go about it?
13 Replies 13
Without the use of ACLs restricting Inter-VLAN routing, these two subnets will be able to communicate with each other by default once the VLANs are properly configured.
So attached is my running-config. Mind taking a look and seeing what I'm missing? I have no ACLs, the VLANs are configured with the separate subnets and I have IPv4 Routing enabled but I haven't been able to get them to communicate.
i do not see any issue in the config, it is just a simple config.
thinks me that it is an end device issue with windows FW, how are you testing reachability  Ping ?
can you also post the outcome of the test here?
also from switch
show ip interface brief
show ip route
BB
That's why I've been confused - there's not much to this config.
I am testing via ping so guess it could be Windows related:
Pinging 192.168.1.202 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.202:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
From switch:
switch7feacb#show ip interface
IP Address I/F I/F Status Type Directed Prec Redirect Status
admin/oper Broadcast
172.22.254.254/16 vlan 10 UP/UP Static disable No enable Valid
192.168.1.1/24 vlan 20 UP/UP Static disable No enable Valid
switch7feacb#sh ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
C 172.22.0.0/16 is directly connected, vlan 10
C 192.168.1.0/24 is directly connected, vlan 20
@MikeWerner0426 wrote:
I have VLAN 10 set up with a IP of 172.22.0.0/16 - no dhcp range
I have VLAN 20 set up with a IP of 192.168.1.1/24 and DHCP with some addresses in that range
I have one device that needs to live in VLAN 10 and have a IP in that range, but needs to communicate with another device in VLAN 20.
 So your VLAN 10 host is a Windows PC statically-assigned 172.22.254.250. And your VLAN 20 unknown host is assigned 192.168.1.202 via the switch's DHCP server.
I.e.:
VLAN 10 host: 172.22.254.250/172.22.254.254
VLAN 20 host: 192.168.1.202/192.168.1.1
Can you confirm IP addressing on VLAN 20 host by posting relevant output?
What type of device is the VLAN 20 host?
Yes - IP address for the VLAN 20 device is 192.168.1.202/255.255.255.0/192.168.1.1
It is a touch panel - manufacturer unnamed. And it does accept pings, can ping directly from the switch without any issue. But I have tried with another PC as well to see if I could ping one way or the other but it is the same result.
balaji.bandi
from PC you should able to ping
gateway of VLAN 10 and 20 ? then most windows FW here.
BB
Can ping GW of VLAN 10:
Pinging 172.22.254.254 with 32 bytes of data:
Reply from 172.22.254.254: bytes=32 time=1ms TTL=64
Ping statistics for 172.22.254.254:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 1ms, Average = 1ms
Can't ping GW of VLAN 20:
Pinging 192.168.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.1:
balaji.bandi
what is the device IP ? can you post ipconfig /all ?
from VLAN 20 device can able to ping 192.168.1.1 ?
go to the video : ( make sure you have tick box ipv4 routing enabled)
https://www.youtube.com/watch?v=NLMKwYSlQDY
Layer 3 enabled?
https://community.cisco.com/t5/network-management/hidden-system-mode-layer-2-and-3-button-in-administration-gt/td-p/3092916
BB
Yes to being able to ping 192.168.1.1 from the VLAN 20 device.
Device IP is 172.22.254.250
ipconfig:
Ethernet adapter Ethernet 3:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek USB GbE Family Controller
Physical Address. . . . . . . . . : 00-E0-4C-01-4B-E0
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::5529:ca24:a033:362%22(Preferred)
IPv4 Address. . . . . . . . . . . : 172.22.254.250(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 172.22.254.254
DHCPv6 IAID . . . . . . . . . . . : 872472652
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-26-75-76-24-B8-31-B5-3F-13-0A
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Do check the above setting as advised in other posts.
BB
Yeah, I've been through those already and have the settings per the recommendations.
If you have done all, Kindly share the screenshot for us to verify why this was not working as expected.
Since this is new i would suggest to reset to Factory and start over fresh and post the outcome.
BB
