08-20-2019 12:09 PM
I have Cisco SG500-52P switches. I have a switch that I have split into 2 VLANS, ports 2-24 are on VLAN 2 and 25-48 are on VLAN 4. The problem is with the VLAN 4 ports, my settings have not changed on the VLAN 4 ports, however, they no longer have access to the internet plus they receive a 169.X.X.X ip address. The VLAN 4 ports are supposed to have an IP address starting with 172.27.X.X and connect to the internet. Has anyone seen this before?
Solved! Go to Solution.
08-21-2019 09:37 AM
I got it figured out. The problem was not the switch but the firewall port. Thanks
08-20-2019 12:50 PM
08-21-2019 05:26 AM
I'm attaching screen shots. This set up worked before but the issue now is I can't get to the internet through this switch. Pinging google doesn't work. It is uplinked to a Meraki switch and the uplink port seems to be working on the Meraki switch so I'm pretty sure it's this SG500 switch, although, I can't find where any settings have changed.
08-21-2019 09:37 AM
