Cisco sge2010p LAG to HP procurve switch
krzysztofsyguda
Hi;
I have configured  stack with 2 sge2010p switches. I want to connect this stack to the HP procurve switch using port agregation (LAG) technique.
I want to use one ge port on each sge switch.
How to configure it? Will it work witch port agregation on procurve?
Should I enable STP on LAG interface?
David Carr
Level 6
Level 6
Krzysztof,
In theory, this should work, since you have the sge2010's in a stack it should work.  I have not tested this personally.  Of course if it don't work, you can still  have the redundency of having 1 port from each switch going to the procurve with rstp enabled.
nimusell
Dear Krzysztof,
Thank you for participating in the Small Business support community. My name is Nico Muselle from Cisco Sofia SBSC.
As for your first question, yes, ports from 2 different switches in stacking mode can be added to the same LAG.
For STP settings, as the switch configures the LAG as being one port, you have to configure these settings on the LAG, not on the separate ports.
Hope this helped,
Best regards,
Nico Muselle
Sr. Network Engineer - CCNA
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
