09-11-2019 03:32 AM
Hello!
Is there way using tacacs authentication login directly into enable mode?
09-16-2019 12:41 AM
Hi there,
You log straight into EXEC mode you need to pass a privilege parameter with a value of 15 as part of the authorization policy result.
Try following the following guide (don't worry about the command set elements):
http://www.omnisecu.com/ccna-security/cisco-secure-acs-shell-profiles-and-command-sets.php
cheers,
Seb.
Log in to Community
