CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
135
Cisco Small Business (eg SG300, SF300) tacacs authentication directly to enable mode
Hello!
Is there way using tacacs authentication login directly into enable mode?
1 REPLY 1
VIP Advisor
Re: Cisco Small Business (eg SG300, SF300) tacacs authentication directly to enable mode
Hi there,
You log straight into EXEC mode you need to pass a privilege parameter with a value of 15 as part of the authorization policy result.
Try following the following guide (don't worry about the command set elements):
http://www.omnisecu.com/ccna-security/cisco-secure-acs-shell-profiles-and-command-sets.php
cheers,
Seb.
