11-17-2018 02:22 AM
I have the below requirement.
I have a Windows 10 Physical PC & inside the PC I do have a windows10 Virtual VM.
I want to connect the Physical PC to the network access layer switch port.
Requirement is that the Physical PC & the virtual PC should get IP address from different VLAN.
Let me know if this is possible. If possible let me know what configurations are required in the network access layer switch.
11-17-2018 05:39 AM
If PC have have dual NICs (or USB to Ethernet adapter available in the market for cheap price), differentiate with 2 networks or VLANs.
11-17-2018 06:56 AM
11-17-2018 07:00 AM
If the network card in the PC supports vlans, you should be able to configure vlans on the PC and connect to different networks. Check the drivers for your network card. On the switch you will need to configure the port to the PC as a trunk with the requisite vlans.
John
11-17-2018 05:05 PM
Let me know what configurations needed to be done in PC.
Any reference or document which shows what configurations needed to be done ?
11-18-2018 10:56 AM
Look at the example Intel network card have support VLAN (attached image for reference)
11-21-2018 07:55 PM - edited 11-21-2018 07:56 PM
11-21-2018 10:05 PM
What network card you have?
John
11-22-2018 12:08 AM
Your nic already bound to vNIC, so unbind and start doing again.
