CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
487
Beginner
CLI for SE2010
Hi Team,
We just purchased this device and was curious if the firmware 3.0.2.0 or 3.0.1.0 has the CLI functionality like the Sx300 models with 1.1.2.0.  I find it easier to configure via CLI then the WebUI.
Please advise.
Thanks for any input
Advocate
CLI for SE2010
Hello Eisada,
There is a backdoor CLI for the SGE/SFE2000/2010 switches. However, the feature is unsupported and not recommended to use. Additionally, if you enable the CLI view on the console, there is not an exit command to go back to the menu driven supported configuration.
To access this configuration you can telnet to the switch (if you enable Telnet under the Bonjour tab) or console the switch. Authenticate as you normally would.
Press  ctrl+z  at the same time then type LCLI and hit enter. This will toggle the CLI and a 'normal login'.
-Tom
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Highlighted
Beginner
CLI for SE2010
I meant SGE2010.
Advocate
CLI for SE2010
My response is still valid.
-Tom
Ask the Expert- Webex Hybrid Services Solutions
