02-26-2015 08:43 AM
Hello, i use SG300-10. I need OID to change 1000M in 100M (Configure Port settings)
Solved! Go to Solution.
02-27-2015 08:49 AM
03-01-2015 03:45 PM
Hello Aleksandra
yes, that's the correct interface speed table, for SG300-10 switch, it could look like this by default:
CISCOSB-rlInterfaces::swIfSpeedAdminMode.49 = INTEGER: 1000000000 CISCOSB-rlInterfaces::swIfSpeedAdminMode.50 = INTEGER: 1000000000 CISCOSB-rlInterfaces::swIfSpeedAdminMode.51 = INTEGER: 1000000000 CISCOSB-rlInterfaces::swIfSpeedAdminMode.52 = INTEGER: 1000000000 CISCOSB-rlInterfaces::swIfSpeedAdminMode.53 = INTEGER: 1000000000 CISCOSB-rlInterfaces::swIfSpeedAdminMode.54 = INTEGER: 1000000000 CISCOSB-rlInterfaces::swIfSpeedAdminMode.55 = INTEGER: 1000000000 CISCOSB-rlInterfaces::swIfSpeedAdminMode.56 = INTEGER: 1000000000 CISCOSB-rlInterfaces::swIfSpeedAdminMode.57 = INTEGER: 1000000000 CISCOSB-rlInterfaces::swIfSpeedAdminMode.58 = INTEGER: 1000000000
But to set speed for example on port GigabitEthernet 5 to 100M, you have to perform two commands:
snmpset -v 2c -c RWCommunitySecret X.X.X.X CISCOSB-rlInterfaces::swIfSpeedAdminMode.53 i '100000000' snmpset -v 2c -c RWCommunitySecret X.X.X.X CISCOSB-rlInterfaces::swIfSpeedDuplexAutoNegotiation.53 i '2'
The first one sets the speed to 100M, in reality option "speed 100" will be appended to running config for interface GigabitEthernet 5, but nothing happen in reality - port will still operate at negotiated speed 1000M.
In order to force 100M speed, you have to disable negotiation for that port - that's the second command - option "no negotiation" will be appended to to running config for interface GigabitEthernet 5. Value '2' means "Disable". To enable negotiation back on, perform same command with '1' at the end ('1' means "Enable").
02-27-2015 08:49 AM
Please try .1.3.6.1.4.1.9.6.1.101.43.1.1.15
Aleksandra
03-01-2015 03:45 PM
Hello Aleksandra
03-02-2015 12:38 AM
Thank you verry much.
