CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
371
o0oinsomniao0o
Beginner
configure Port settings
Hello, i use SG300-10. I need OID to change 1000M in 100M (Configure Port settings)
2 ACCEPTED SOLUTIONS
Aleksandra Dargiel
Please try .1.3.6.1.4.1.9.6.1.101.43.1.1.15
Aleksandra
Hello Aleksandra
yes, that's the correct interface speed table, for SG300-10 switch, it could look like this by default:
CISCOSB-rlInterfaces::swIfSpeedAdminMode.49 = INTEGER: 1000000000
CISCOSB-rlInterfaces::swIfSpeedAdminMode.50 = INTEGER: 1000000000
CISCOSB-rlInterfaces::swIfSpeedAdminMode.51 = INTEGER: 1000000000
CISCOSB-rlInterfaces::swIfSpeedAdminMode.52 = INTEGER: 1000000000
CISCOSB-rlInterfaces::swIfSpeedAdminMode.53 = INTEGER: 1000000000
CISCOSB-rlInterfaces::swIfSpeedAdminMode.54 = INTEGER: 1000000000
CISCOSB-rlInterfaces::swIfSpeedAdminMode.55 = INTEGER: 1000000000
CISCOSB-rlInterfaces::swIfSpeedAdminMode.56 = INTEGER: 1000000000
CISCOSB-rlInterfaces::swIfSpeedAdminMode.57 = INTEGER: 1000000000
CISCOSB-rlInterfaces::swIfSpeedAdminMode.58 = INTEGER: 1000000000
But to set speed for example on port GigabitEthernet 5 to 100M, you have to perform two commands:
snmpset -v 2c -c RWCommunitySecret X.X.X.X CISCOSB-rlInterfaces::swIfSpeedAdminMode.53 i '100000000'
snmpset -v 2c -c RWCommunitySecret X.X.X.X CISCOSB-rlInterfaces::swIfSpeedDuplexAutoNegotiation.53 i '2'
The first one sets the speed to 100M, in reality option "speed 100" will be appended to running config for interface GigabitEthernet 5, but nothing happen in reality - port will still operate at negotiated speed 1000M.
In order to force 100M speed, you have to disable negotiation for that port - that's the second command - option "no negotiation" will be appended to to running config for interface GigabitEthernet 5. Value '2' means "Disable". To enable negotiation back on, perform same command with '1' at the end ('1' means "Enable").
3 REPLIES 3
Aleksandra Dargiel
Aleksandra
Hello Aleksandra
Thank you verry much.
