Configuring 2960 and 300 ES switches
mpetrella
I have a 2960S switch and nine (9) 300 switches. I have three VLANs configured on them, data, voice and management. Each 300 has unique data and ovice VLANs corresponding to their locations. All of the 300 switches connect to the 2960 in a hub and spoke network topology via 802.1q trunks. I can access devices between switches on the data and voice VLANs fine from any other switch. My issue is that from any 300 switch I can access the 2960 management VLAN interface without a problem, but I can not access the 300 switch management VLAN that I am connected to from the CLI. I do not use the GUI at all for management.
Am I missing something.
22 Replies 22
Tom Watts
Hello meptrella, I'm assuming the 300 ES switches are SX300 series models.
The switch is not accessible via any method but http or console without first being 'activated'.
config t
ip telnet server
This should allow telnet from the 2960 to the SX300 series. You can also enable ssh the same way
config t
ip ssh server
If the SSH keys are not generated the SSH server may wait until the keys are generated
crypto key pubkey-chain ssh
user-key ******
key-string rsa
* = whatever you want
-Tom
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Thanks Tom. This solved a piece of the puzzle, but brought up another issue.
I am not sure if it is a telnet server issue. The reason I say that is I added the suggested commands. I can access the 300 switches from the 2960 now. If I am connected to the 300 I can not access its management address. I can ping the 2960 management address, the 300 gateway, other devices on the 300, but not the management interface address on VLAN one.
Any ideas?
Mike
In layer 3, if there is not a device connected on the IP interface, there won't be a response. Perform a show ip route, you will notice a default route is built, additionally you will notice routes built to each subnet for an active interface.  If you connect a device to the ip interface, the ip route will dynamically build and the interface will respond.
If the switch is in L2 then it should simply work
-Tom
I may be in over my head. I could not do the ip routing command on the 2960 and I thought the 300's were all layer 2 devices. I have worked on the Cisco Enterprise switches for about 10 years and many of the "normal" switch commands are not there. There is no router in the network so we have to work with the 16 static routes on the 2960 and  default gateway on the 300. Again, I may be missing something on these. We had nothing to do with the selection of the switches and have to get them working for the three VLANs.
Mike
On the SX300, in the layer 2 mode, the IP address does not matter for the device except management purpose. So, what to do, connect a computer via ethernet to the SX300 on a port part of the management VLAN, assign a static IP address to the computer and see if you can open the GUI and ping the switch.
If successful, directly connected to the switch, then we know there is either an incorrect configuration, an incorrect route on the 2960 or the device attempting to access the switch IP interface is not on the management ip subnet.
-Tom
I will try that this weekend. I will post the results Monday.
Thanks again for all the help.
Mike
Back again. We have VLAN 1, VLAN 10 and VLAN 11 on the 300ES and 2960. The 2960 has VLAN interfaces configured on the 2960 as well as the VLAN database. The 300ES has the VLAN database, but no VLAN interfaces configured on it. We have trunks between the switches. The 300ES has ports assigned to VLAN 10 with VLAN 11 being the VoIP.
I did as suggested and the results were as follows:
1) We can now get between all switches on VLAN 1.
2) If we have a PC on VLAN 10 on the 300ES we can not ping any interface on the 2960. From the 2960 we can not ping the PC on the 300ES sourcing it from the VLAN 10 interface address on the 2960.
3) From the 300ES we can ping the gateway defined on the 2960 for VLAN 10, but can not ping anything off of the VLAN 10 network.
I have to be missing something stupid. I set this up with 4500 and 3750 with no problems, but the CLI on the 300ES and 2960 do not match the higher switches and I can not figure out what the miussing piece is on this.
Any help is appreciated.
Mike
Hi Mike, can you post a show run for each switch?
-Tom
Tom,
I will have to do it tonight. I left my thumb drive at home.
Mike
Tom,
My fellow engineer had the configs and sent them to me.The configs are below. The 2960 is first. One additional test we did was to have a PC on VLAN 10 on the 2960 and one on the 300ES and could not ping between them either. Thanks again.
Building configuration...
Current configuration : 11609 bytes
version 12.2
no service pad
service timestamps debug datetime localtime
service timestamps log datetime localtime
hostname 2960-MDF-1
boot-start-marker
boot-end-marker
enable secret 5 $1$6yul$iZz2Rj6HA8JHl2KMHxF16/
username lns privilege 15 secret 5 $1$A129$F19PkQvMBPoRbT.z4ldwB.
username cisco privilege 15 secret 5 $1$sAYS$mdeBRQa/Yfhh6RoTEcd9x1
no aaa new-model
clock timezone UTC -5
clock summer-time UTC recurring
switch 1 provision ws-c2960s-48fps-l
ip routing
vtp mode transparent
udld aggressive
crypto pki trustpoint TP-self-signed-2638571776
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2638571776
revocation-check none
rsakeypair TP-self-signed-2638571776
crypto pki certificate chain TP-self-signed-2638571776
certificate self-signed 01
  30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32363338 35373137 3736301E 170D3933 30333031 30303033
  30365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36333835
  37313737 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CBED 28723530 0501217D 4FBE6C5B B902D9B8 2A9D7A10 67503A3A B47B4097
  0C6BA011 D14837A1 B1E169A7 D0FF03A1 AADBA145 BCD6937A 0B05BDC6 227C9FF1
  AA692CE7 720E3D8D 7724FD7D 794778F9 61702964 080872D9 E9A52437 D67B2DA6
  18E1D1EC B7827EB2 4EBF8D82 6A15655E 66D1B9DC C67661D3 86908DC6 60935A63
  81E90203 010001A3 6B306930 0F060355 1D130101 FF040530 030101FF 30160603
  551D1104 0F300D82 0B323936 302D4D44 462D312E 301F0603 551D2304 18301680
  145CC643 4DF22380 B319CD2F 65AB80C7 DBFE044B 17301D06 03551D0E 04160414
  5CC6434D F22380B3 19CD2F65 AB80C7DB FE044B17 300D0609 2A864886 F70D0101
  04050003 818100CA 5EF4A7F4 E97C67B2 38062B1A B1C9A132 499EFE7F A00F4897
  84CA79E9 7C0E0C77 0899B745 5D2D69B0 BB3E2495 6E98D522 7B8BA267 A766460F
  BB319F55 A7B1C752 EC4D4EEF 84B51524 56C3003B D8D0F970 F3BEA90B 7B668399
  AA08760D F5598EEE E25CA8D7 59F11EC3 94B25B97 9FC4D6BE DF1AD4C9 FEC88DA2
  08DB8A4A 6A1DFD
  quit
spanning-tree mode rapid-pvst
spanning-tree portfast bpduguard default
auto qos srnd4
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
vlan internal allocation policy ascending
vlan 10
name BLDG-10
vlan 11
name VoIP-BLDG-10
vlan 100
name SERVERS
ip ssh version 2
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
switchport access vlan 100
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
description SF300-BLDG10-1 Port G1
switchport mode trunk
mls qos trust dscp
interface GigabitEthernet1/0/48
description SF300-SALES Port G1
mls qos trust dscp
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
description Management
ip address 10.0.5.1 255.255.255.0
ip helper-address 10.0.0.24
interface Vlan10
description BLDG-10
ip address 10.0.10.1 255.255.255.0
interface Vlan11
description VoIP BLDG-10
ip address 10.0.11.1 255.255.255.0
interface Vlan100
description SERVERS
ip address 10.0.0.1 255.255.255.0
ip default-gateway 10.0.0.5
no ip route static inter-vrf
ip route 10.0.10.0 255.255.255.0 10.0.5.10
no ip http server
ip http secure-server
line con 0
line vty 0 4
logging synchronous
login local
transport input telnet ssh
line vty 5 15
logging synchronous
login local
end
One of the nine (9) 300ES follows.
SF300-BLDG10-1(config)#do sho run
interface range fa1-48
exit
interface  fa48
exit
interface  gi1
description "MDF-1 Port 1/45"
exit
vlan database
vlan 10-11
exit
voice vlan id 11
voice vlan state auto-enabled
voice vlan cos 6 remark
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 001049 shoretel
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
interface vlan 1
ip address 10.0.5.10 255.255.255.0
exit
ip default-gateway 10.0.5.1
interface vlan 1
no ip address dhcp
exit
hostname SF300-BLDG10-1
no passwords complexity enable
ip ssh server
ip telnet server
interface fastethernet1
switchport trunk allowed vlan add 11
switchport trunk native vlan 10
exit
interface fastethernet2
exit
interface fastethernet3
exit
interface fastethernet4
exit
interface fastethernet5
exit
interface fastethernet6
exit
interface fastethernet7
exit
interface fastethernet8
exit
interface fastethernet9
exit
interface fastethernet10
exit
interface fastethernet11
exit
interface fastethernet12
exit
interface fastethernet13
exit
interface fastethernet14
exit
interface fastethernet15
exit
interface fastethernet16
exit
interface fastethernet17
exit
interface fastethernet18
exit
interface fastethernet19
exit
interface fastethernet20
exit
interface fastethernet21
exit
interface fastethernet22
exit
interface fastethernet23
exit
interface fastethernet24
exit
interface fastethernet25
exit
interface fastethernet26
exit
interface fastethernet27
exit
interface fastethernet28
exit
interface fastethernet29
exit
interface fastethernet30
exit
interface fastethernet31
exit
interface fastethernet32
exit
interface fastethernet33
exit
interface fastethernet34
exit
interface fastethernet35
exit
interface fastethernet36
exit
interface fastethernet37
exit
interface fastethernet38
exit
interface fastethernet39
exit
interface fastethernet40
exit
interface fastethernet41
exit
interface fastethernet42
exit
interface fastethernet43
exit
interface fastethernet44
exit
interface fastethernet45
exit
interface fastethernet46
exit
interface fastethernet47
exit
interface fastethernet48
exit
interface gigabitethernet1
no macro auto smartport
switchport trunk allowed vlan add 10-11
exit
Fat fingered my last two posts. One the 2960 we had a PC on VLAN 100, not 10.
switchport trunk allowed vlan add 10,11,100 <- Try this
mls qos trust dscp
spanning-tree mode rapid-pvst <-- SX300 does not support the PVST. I am not sure if it makes a difference
auto qos srnd4
SX300 port-
switchport trunk allowed vlan add 10-11  <- VLAN 100 is not a member of the port (I think this is your uplink?)
exit
switchport trunk allowed vlan add 10,11, this means the port is 1untag, 10 and 11 tag.
-Tom
WIll try the suggested confifuration changes tonight.
One questions, why would I need to include the VLANs in the allowed statements? The reason I ask is that with the 4500 and 3750 we use we don't have them specifically and things work fine.
Mike
Ingress filtering on trunk and access port will discard any vlan id not specified on the port of the SX300.
-Tom
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
