CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1122
PatrickB.
Beginner
Connecting 886va <-> sg200-08p via access ports: Port Type Mismatch
Hi.
We recently bought a SG200-08P to replace our older switch.
After a hassle to configure / clone our configurations (e.g. defining a different Vlan than Vlan1 as the management Vlan without "losing" a precious port ;)) via GUI, we were finally able to switch the switches.
However, I ran in a problem in connecting a 886VA Router to the SG200-08P Switch:
I want vlan 105 on the Router to receive an IP Address via an existing DHCP-Server in vlan105 that's trunked through a port at the SG200-08P (g8).
Fa0 <-> g5 - Both are configured as Access Ports and the SG200-08P still seems to be in trunking mode?
I keep receiving the following messages on the Router:
%SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk FastEthernet0 VLAN105.
%SPANTREE-7-BLOCK_PORT_TYPE: Blocking FastEthernet0 on VLAN105. Inconsistent port type.
See also:
VLAN105 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 65535, address X
  Configured hello time 2, max age 20, forward delay 15
  We are the root of the spanning tree
  Topology change flag not set, detected flag not set
  Number of topology changes 0 last change occurred 00:01:43 ago
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 1, topology change 0, notification 0, aging 300
Port 1 (FastEthernet0) of VLAN105 is broken (Port Type Mismatch)
   Port path cost 19, Port priority 128, Port Identifier 128.1.
   Designated root has priority 65535, address X
   Designated bridge has priority 65535, addressX
   Designated port id is 128.1, designated path cost 0
   Timers: message age 3, forward delay 14, hold 0
   Number of transitions to forwarding state: 0
   BPDU: sent 51, received 0
Is it safe to say, that this is a problem with the SG200-08P?
If configured as trunking ports, vlan105 receives an IP Address - but that isn't what I am looking for. I need fa0 to be an access port.
Relevant configurations of the 886VA and 200SG-08P are pasted below.
Lots of thanks in advance!
Greets,
Patrick
886VA:
spanning-tree vlan 105 priority 65535
interface FastEthernet0
switchport access vlan 105
no ip address
interface FastEthernet1
no ip address
shutdown
interface FastEthernet2
no ip address
shutdown
interface FastEthernet3
no ip address
shutdown
interface Vlan105
ip address dhcp
FastEthernet0 is up, line protocol is up
  Hardware is Fast Ethernet, address is X (X)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3000 bits/sec, 3 packets/sec
     38458 packets input, 3527192 bytes, 0 no buffer
     Received 28616 broadcasts (9782 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     4414 packets output, 341492 bytes, 0 underruns
     0 output errors, 0 collisions, 13 interface resets
     50 unknown protocol drops
     5 lost carrier, 0 no carrier, 0 pause output
SG200-08P (backup configuration):
interface g5
spanning-tree edgeport
no spanning-tree auto-edge
no spanning-tree port mode
switchport mode access
exit
1 REPLY 1
jeffrrod
Enthusiast
Dear Patrick,
Thank you for reaching the Small Business Support Community.
I see nothing wrong with the actual configurations, there should not be any Port Type Mismatch in my opinion and I am afraid I have nothing to suggest you but to contact the Small Business Support Center directly and have a TAC engineer figure this out with you;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach me back if there is anything I may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
