02-28-2014 12:59 PM
I am having problem connecting my ESW 540 to the new additional switch Csico SG300. Is the uplink port need to be configured differently?
The port on the ESW becoming inactive when I connected to SG 300 port.
Thank you.
Solved! Go to Solution.
02-28-2014 03:04 PM
02-28-2014 01:36 PM
Untung,
Check the SmartPort and Spanning Tree settings on each switch.
- Marty
02-28-2014 02:49 PM
Thank you Marty,
I read some of the discussion, I am assuming the STP has to be disabled on both siwtch for that particular ports. But I am not sure if I have to specify the smarport to specificaly for switch on the SG 300.
02-28-2014 03:04 PM
Untung,
Specify Switch or disable SmartPort Role on the port.
- Marty
02-28-2014 03:54 PM
Thank you. That works.
