CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
2835
mgryzeni
Convert CE500 config to 2960
Is there any tool to port a CE500 configuration over to 2960.  The CE500 config has much more than is needed.  Is it required for the process to be done manually?
2 ACCEPTED SOLUTIONS
Maulik Shah
Contributor
Checked with the 2960 team and unfortunately this is manual today.
Glenn Quesenberry
No "porting" tool.  Different device platforms with different means of configuring/managing them (CCA or on-board UI for the CE500 & CNA or CLI for the 29XX).  Looks like manual is the only way unfortunately.
Glenn
3 REPLIES 3
Maulik Shah
Contributor
Glenn Quesenberry
Glenn
mgryzeni
Thank you.
Mark
