07-23-2009 06:33 AM
Is there any tool to port a CE500 configuration over to 2960. The CE500 config has much more than is needed. Is it required for the process to be done manually?
Solved! Go to Solution.
07-23-2009 08:53 AM
Checked with the 2960 team and unfortunately this is manual today.
07-23-2009 09:56 AM
No "porting" tool. Different device platforms with different means of configuring/managing them (CCA or on-board UI for the CE500 & CNA or CLI for the 29XX). Looks like manual is the only way unfortunately.
Glenn
07-23-2009 08:53 AM
07-23-2009 09:56 AM
Glenn
07-23-2009 11:19 AM
Thank you.
Mark
