04-29-2011 11:31 AM
I need create 2 vlans (vlan 10 and vlan 30) in Cisco 300 Series Switch.
VLAN 10 need be default VLAN (no tag).
After I wish associate port 1 to VLAN10 and port 2 to VLAN 30. The two ports must be access.
Can anyone give a step-by-step for this??
Best Regards.
Solved! Go to Solution.
05-01-2011 10:12 PM
Hi Andre,
Made a fiour minute video to show you how to create two vlans and I believe answer your question.
After you make the changes, i have suggested, be sure to save the configuration within the switch.
( the audio died whilst i was starting to save the running config to the startup configuration )
Also , it isn't indicated clearly, but in the "port to VLAN" page make sure you select go after you select a VLAN to modify. See the encircled go button in the screen shot below.
Click here to see the 4 minute video or the link below;
regards Dave
05-01-2011 10:12 PM
Hi Andre,
regards Dave
05-02-2011 06:07 AM
Really Thanks David. Very good the vídeo.
In my config VLAN 10 is default VLAN. This make any change in configurantion of the ports?
One more time thanks.
