Dear Patrick,
Thank you for the feedback to the Small Business Support Community. You are right, the CSCuh07704 has already been given the "Resolved" status by 09-22-2013 and will be covered in the new firmware release, and just to give others a better idea of what the problem was:
B>Symptom:
Hosts will obtain incorrect IP address.
Conditions:
Issue occurs when the switch is in Layer 3 mode and embedded DHCP server is enabled.
Thank you again for your commitment and please do not hesitate to reach us back if there is anything we may assist you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
