10-11-2011 01:35 PM
I have a recently purchased 28 port SG300 switch. Everything is working well. Unfortunately there is so much traffic flying around that a 10MB half duplex device is struggling to function as it is overloaded. Removing some of the sources of traffic fixes it.
Fortunately I only need to access that device from one PC on the network. That PC however needs to access everything else on the network.
Is there a simple way to shield the slow device from everything except traffic from the PC ?
The switch is in Level2 mode at the moment.
Everything is on a single subnet.
10-12-2011 05:50 AM
Hi Chris,
wow interesting synopsis, I'm guessing this traffic may be multicast IP traffic or a very busy broadcast network?.
I think, you are inclinded to putting the switch into layer 3 mode and run layer 3 switching between two vlans, the existing vlan and a VLAN containing the 10MB half duplex device?
Could be a instant way to reduce broadcast and/or multicasts hitting the 10MB half duplex device from the existing network.
regards Dave
10-13-2011 02:26 AM
Thanks Dave,
I will give that a try.
Randomly other that the user guide, are there any intro guides on these switches you have ever seen ?
Just thought I would ask
Chris
