CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
8324
Highlighted
Beginner
Disable password expiration requirement on SG300
I have a dozen or so SG300 switches and a few months after configuring and deploying them, I have noticed that as I'm logging back into them, I'm being told that I'm required to change my password as it has expired.  The problem I have with this is that we pick a super complex password and stick with it because we have bots that telnet to the switches and pull configs and make config changes.  I do NOT wish to have this enforcement turned on for these switches and I think it should be an option but neither the Admin Guide, the command line, nor the GUI seem to have any mention of this "feature".  Anybody know how to disable this feature?
Everyone's tags (2)
3 REPLIES 3
Highlighted
Beginner
I'd like to answer my own question.  From the CLI, I found the command "no passwords aging".  This should do it.  I'm trying it now.  On a related topic, does anybody know the aging period, i.e. how long before the password expires if one should have this feature enabled?
Participant
Hello Pete,
You can use the following CLI command 'password aging 0' which should set it to no timeout. The password aging setting can be found under Security > Password Strength in the webGUI. The default timeout is 180.
Highlighted
Beginner
I see it.  Thanks!  I wonder why the Admin Guide doesn't mention it.
