05-20-2012 04:53 AM
I have more than 20 SF 300-24P 10/100 Managed Switch switches deployed and running in my office network. All these switches have web configuration utility enabled. We would like to enable telnet too. But for this I know I have to visit site to site, connect the switch manually with a laptop and enable telnet option.
I am looking for how can I enable telnet in these swithches using web-based switch configuration utility.
Can anyone please help..
Solved! Go to Solution.
05-20-2012 10:32 PM
Wrong forum, try "small business - switches". You can move your post using the Actions panle on the right.
05-20-2012 10:32 PM
05-21-2012 10:21 AM
Thank you very much.
05-23-2012 05:28 AM
Hi AKM and Paolo
This is not a bad area for the question, we are in small business switches
step 1. Make sure you are using the most current firmware on your switches.
Perform any firmware upgrades as required.
Step 2. Goto security Tab >TCT/UDP services and tick the telnet service
Step 3 remember to save your changes to copy the running configuration to the startup configuration
regards Dave
