ESW-520(s) and VLANs
Hi guys,
We have roughly 14 ESW-520 switches through out our network which connect wireless APs. We also have 3 VLAN (VLAN1 data; VLAN4 wireless; VLAN100 voice). The access points need to be getting an IP address from the DHCP server on VLAN4 but they end up getting VLAN1 IPs instead. I am guessing this is because the untagged VLAN1 is by default and we do need all 3 VLANs trunked to the access points because we have SSID for voice and one for data.
Is there something I can do on the switches so that the APs get VLAN4 IPs?
Many thanks,
Dmitry
rocater
Level 3
Level 3
Hello Dimawerks,
On the switch you can only really change the untagged vlan to be 4. The option you are looking for should be available on the AP. Ideally you are wanting the management of the AP to be on vlan 4. The best way to set this is on the AP to have it's management vlan changed to 4 and to then to tag it on the AP and switch or untag it on both.
