Firmware 1.4.0.88 for SG300-52 appears to break DHCP Relay
Jonathan Fisher
My VLANs terminate at my switches, so I use DHCP relay with Option82 to hand out addresses for the VLAN subnet. After upgrading from 1.3.7.18 to 1.4.0.88, DHCP isn't being handed out on my VLANs. Anyone else having this problem?
39 Replies 39
Confirmed... I'm seeing the exact same behavior! Nice find.
Here are two packet captures from the SG300 to my DHCP server:
1.4: https://www.cloudshark.org/captures/f74bcfad752c
1.3: https://www.cloudshark.org/captures/76360f902726
Yes, it does change but no issue with Windows 2008 server.
What is your DHCP server?
Aleksandra
Dnsmasq version 2.68
Have you seen this working before with any other DHCP relay agents?
Aleksandra
Yes. dnsmasq is incredibly prolific, it's used in nearly every open source router.
No doubt about this. Just there is a small difference between relay and regular DHCP discovery/request.
If you want to try to reproduce, Download a distribution that includes dnsmasq as it's DHCP server or just run Ubuntu from a live USB.
If there are other packet captures or anything else I can do on my network to give you information, I'm more than willing to help. I want to keep my firmware current but at this rate we'll be stuck on 1.3 forever.
Hi Jonathan,
I guess it would be good idea to open an official ticket with Small Business Support team so we will document everything in details:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
vignal-systems
Hello All,
It's the same for me here. DHCP was working before upgrade but not after.
Windows clients can obtain IP on the vlan but wyses clients and windws CE clients fail to have IP via DHCP relay.
Have not seen such an issue yet but if there is a problem with latest firmware I strongly recommend you to open ticket with Small Business team so they can narrow down and if needed open bug:
Aleksandra
I've no open contrat for our SMB switch so no support...
May be I've found a workaround for this issue. After many many try this issue seams to not be a DHCP relay issue but a global routing break that cause DHCP relay very very slow and cause timeout for some DHCP clients (in my case Wyse ThinOS).
The solution for me was to increase TCAM routing ressource from 128 to higher value.
We upgrade from firmware 1.0 to 1.4 and I belive that TCAM partitioning was quite different.
That's why I could not reproduce the issue in test or mock-up pre-update systems.
Could you confirm that:
-Is it normal to have, for each host routed via SG300, 1 Neighbors TCAM entry? So Sg300 limit routing to -+400 hosts dependent of ACL / Services and routing interface in configuration.
-Do you have TCAM count of new Sg500?
Many thanks in advance.
I reply to my previous post: as I can find on internet SG500X device is 3072 TCAM entries and the Sx500 device is 2048.
Is there a log entry or anything that would indicate it has ran out of TCAM resources?
We have theses log entry :
Error   %ARP-E-ARPTBL: ARP Table Overflow, aggregated (3)
Error   %ARP-E-ARPTBL: ARP Table Overflow, aggregated (9)
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
