CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
3971
Highlighted
Beginner
Get device temperature via CLI on SG300-28PP
Good morning,
according to the CLI manual, release 1.4, page 980 ff. there is a "show environment" command similar to regular Cisco switches. When typing this command in the CLI there's a "Unrecognized command" error message.
Is there any way to get a read on the temperature via CLI, SNMP, ...?
Joerg
7 REPLIES 7
Highlighted
VIP Mentor
what options does it give you in cli , use ? mark see whats available
show e ?
or try show power
Highlighted
show e
eee                    Energy Efficient Ethernet
errdisable           Show errdisable state.
sh power shows the temperature of the PSU
Highlighted
strange doc says its there but not , maybe check your on the latest 1.4 release  sx300_fw-1476.ros
Highlighted
Double checked: I'm on 1.4.7.6
Highlighted
I looked into the CiscoSB-Mibs and found only the PSU temp (OID .1.3.6.1.4.1.9.6.1.101.108.3.1.6.1) and the Temp status (OID .1.3.6.1.4.1.9.6.1.101.53.15.1.13.1).
Could get these infos via snmpget. So it's not the solution I was hoping for but better than nothing at all.
Thanks a lot for your help.
Highlighted
Beginner
show system does this.
example:
FAN is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 23 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 51 Degree Celsius
Red Threshold : 61 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1 Built-in Good
SW Status RPS Name RPS Serial# RPS Port#
1 <> <>
Highlighted
Try the following commands:
switch# show system sensors
switch# show system fan
Hope it helps
Cheers,
Mike
