CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
15157
yezawkhant
Beginner
GLC-T Vs SFP-GE-T
May I know what is the differences between GLC-T and SFP-GE_T?
What I found out through net are as follows :
GLC-T
1000BASE-T SFP RJ45 100m transceiver
Specifications
  • Form Factor: SFP
  • Device Type: Transceiver module
  • Connectivity Technology: Wired
  • Wavelength: n/anm
  • Max Distance: 100m
  • Data Transfer Rate: 1Gbps
  • Fiber Type: n/a
  • Connector: RJ45
  • DDM: Without DDM
  • Operating Temperature: 0~70 °C
  • Application: 1000BASE-T
  • Compliant with MSA SFP Specification
SFP-GE-T
  • 1000BASE-T SFP RJ45 100m optical transceiver
Specifications
  • Form Factor: SFP
  • Interface (Bus) Type: Plug-in module
  • Wavelength: n/anm
  • Fiber Type: n/a
  • Connector: RJ45
  • DDM: Without DDM
So no difference between them?
I need tranceiver module to install on my 2960S and 3750E swithces, of course RJ45 copper wire (Gigabit Eternet).
4 REPLIES 4
Leo L
VIP Community Legend
GLC-T is what you need to order.
Why?
Do SFP-GE-T support various data transfer rate? Say 10 Mbps, 20Mbps or 100 Mbps?
-HTH Karthik.
Leo L
20 Mbps?  NO.  I've never heard of a client who's not following standards.
10/100Mbps will depends in your platform and your IOS.
If you stick the SFP into a 6500, for example, the module will operate in 1 Gbps.
HumanTorch
Contributor
this question was answered here:
https://supportforums.cisco.com/discussion/10288371/what-difference-between-sfp-ge-t-and-glc-t
Difference is only NEBS 3 and DOM in the SFP-GE-T
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
