CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
53
Beginner
GVRP between SG300 and SG350
I have problem with GVRP between SG300-28 and SG350-28P
Port configuration on SG300
SW-S06-01#show gvrp configuration GE 23
GVRP Feature is currently Enabled on the device.
Maximum VLANs: 4094
Port(s)  GVRP-Status Registration Dynamic VLAN  Timers(milliseconds)
                                    Creation    Join      Leave      Leave All
gi23     Enabled     Normal       Enabled       200       600        10000
SW-S06-01#show running-config interface ge23
interface gigabitethernet23
 gvrp enable
 switchport general acceptable-frame-type tagged-only
 switchport general pvid 4095
 switchport mode general
 switchport general allowed vlan add 100 tagged
On SG350
SW-S06-00#show gvrp configuration GE 25
Maximum VLANs: 4094
gi25     Enabled     Normal       Enabled       200       600        10000
SW-S06-00#show running-config interface GE25
interface GigabitEthernet25
 gvrp enable
The SG350 switch receives information about VLANs, but the SG300 does not get information about VLANs from the SG350 switch
SG350
SW-S06-00#show interfaces status GE1
                                             Flow Link          Back   Mdix
Port     Type         Duplex  Speed Neg      ctrl State       Pressure Mode
gi1      1G-Copper    Full    100   Enabled  Off  Up          Disabled Off
SW-S06-00#show interfaces status GE7
                                             Flow Link          Back   Mdix
gi7      1G-Copper    Full    100   Enabled  Off  Up          Disabled On
SW-S06-00#show running-config interface GE1 , GE7
interface GigabitEthernet1
 gvrp enable
 gvrp vlan-creation-forbid
 gvrp registration-forbid
 switchport access vlan 239
interface GigabitEthernet7
 gvrp enable
 switchport access vlan 236
The SG300 should see additional VLANs 236 and 239, but only see VLAN 100
SW-S06-01#show interfaces switchport GE 23
Added by: D-Default, S-Static, G-GVRP, R-Radius Assigned VLAN, T-Guest VLAN, V-Voice VLAN
Port : gi23
Port Mode: General
Gvrp Status: enabled
Ingress Filtering: true
Acceptable Frame Type: admitOnlyVlanTagged
Ingress UnTagged VLAN ( NATIVE ): 4095
Port is member in:
Vlan               Name               Egress rule     Added by
100           ManagementVLAN            Tagged           S
Forbidden VLANS:
Vlan               Name
Classification rules:
Mac based VLANs:
  Group ID   Vlan ID
SG350
SW-S06-00#show version
Active-image: flash://system/images/image_tesla_hybrid_2.5.0.90_release_cisco_signed.bin
  Version: 2.5.0.90
  MD5 Digest: a3518dae9be5eaba8ffd726de14367fa
  Date: 26-Sep-2019
  Time: 16:18:10
Inactive-image: flash://system/images/image1.bin
  Version: 2.4.0.94
  MD5 Digest: 6f5be217100f34929986f2e93dd2d5e9
  Date: 31-May-2018
  Time: 02:39:58
SG300
SW-S06-01#show version
SW version    1.4.10.6 ( date  16-Apr-2019 time  18:35:56 )
Boot version    1.3.5.06 ( date  21-Jul-2013 time  15:12:10 )
HW version    V02
Also tested with SF300-24P  (SW version 1.4.11.2) and does not work with SG350
Everyone's tags (1)
