CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
635
Beginner
How config vlans on sge2010?
Hi everyone,
My english is a little bad, I appreciate if you can help me.
I wish to have 3 vlans.
vlan 10 interface 192.168.10.1
vlan 20 interface 192.168.20.1
vlan 30 interface 192.168.30.1
Port 5-10 to vlan 10
Port 11-15 to vlan 20
Port 16-20 to vlan 30
But I want that for example the port 5 has access to vlan 20.
I have tried config each port(interface) in mode trunk and general, but it doesn't work.
I hope you can help me.
Thank you.
Everyone's tags (1)
3 REPLIES 3
Beginner
Re: How config vlans on sge2010?
Good evening,
What is plugged into port 5? A PC?
The only way for 2 Vlans to be presented to 1 port is to make that port a trunk.
A normal access port can only be a member of 1 vlan. To have a computer access multiple Vlans you will need a router.
A trunk (where you have multiple VLANs) is only used for connecting to either another switch, a router or a device that can read tagged VLAN packets on a switch port, such as a VMware server.
Hope this helps.
Beginner
Thank you bendatcrox for your answer,
Yes, I have plugged into port 5 a PC.
I understand and I'll buy a router to make visible one port in diferents vlans.
If I just want to make two vlans, what I need to do first?
Create IP interface?
Create the vlans?
Add ports to vlans?
Thank you for your help.
Beginner
Evening Luis.
Ok, so a PC can't be a member of 2 VLANS on the same Network card. You therefore have 2 options.
Option 1- you put a second network card into the PC and have one network adaptor on each VLAN
Option 2 (and the better option) - you need a router in your network.
VLANs are virtual LANs. They are separate broadcast domains. The only way for a PC to get to the devices on another VLAN is via a router (L3) devices.
Hope this helps.
Perhaps if you can let me know what the purpose of having a PC on 2 VLANs is, I may be able to assist you with a network design,
Thanks mate.
