CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1024
Highlighted
Beginner
How do I get from a menu at login to CLI on a SG300-28 Switch?
I have a SG300-28 and would like to configure through CLI not menu. How do I get to Cli from Menu?
  I am running Boot version 1.0.0.4 and SW version 1.0.0.27, Do I need to upgrade both boot and SW or Just SW?
2 REPLIES 2
Highlighted
Beginner
Re: How do I get from a menu at login to CLI on a SG300-28 Switc
Hi rod3,
Typically SSH/Telnet is disabled by default on devices.  In order to activate it you will need to go through the WEB GUI to Security > TCP/UDP Services and check the boxes that say SSH or Telnet then click apply.
Then using a Terminal program of your choice you can connect to the switch and configure it.  Be advised that the CLI is not exactly the same as regular IOS.
-Trent Good
** Please rate useful posts! **
-Trent Good ** Please rate useful posts! **
Highlighted
Advocate
CLI was not available on the 1.0.0.27. That was the first production release. If you want the CLI a firmware upgrade is mandatory.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
