How enable 802.1x with 'Wake on LAN' cisco sge 2010 ?
herve97231
We have acquired a cisco sge 2010 to replace our distribution switch. I set up the 802.1X network. Everything works great except I can not find how to enable 802.1x with 'Wake on LAN' on this kind of switch. Do you have an idea?
On catalyst I saw that it was sufficient to activate this control "authentication control-direction {both | in}"
Except that it seems not to exist on this switch. Is there another way to enable 802.1x on WoL without using this command?
Or how to allow the magic packet (WoL) on a tagged port by unauthorized 802.1x?
Thank you in advance
Hervé
Hi Herve, this is unsupported.
-Tom
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
herve97231
Not idéa ?
How 802.1x Unidirectional Controlled Port ?
-Tom
herve97231
Ok merci, avez-vous une idée de comment puis-je autoriser le WoL sur un port controlé par 802.1x ?
Not idéa ?
