how to configure LACP on a SRW2024 switch
net tech
I have a qnap TS-421 nas with two network ports. Both ports are connected to a Linksys srw2024 switch and set to IEEE 802.3ad (Dynamic Link Aggregation). My next task is to configure LACP on switch ports 1 & 13 and I am looking for your help.
Thank you
jeffrrod
Level 4
Level 4
Dear Customer,
Thank you for reaching Small Business Support Community.
Please check on the below document for "How to configure LACP on SRW switches";
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=3564
If there is anything else I may assist you with please do not hesitate to reach me back.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
