CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1731
Highlighted
Beginner
How to configure qinq on SG350?
In the network with SG300 switches I have a new SG350 switch.
How to configure qinq on it?
How should the Customer port be set to SG350? How to trunk between SG300 and SG350? Which Ethertype Tagging should be set?
On SG300 qinq works without problems.
4 REPLIES 4
Highlighted
VIP Mentor
have you tried below example :
interface FastEthernet x/x
switchport access vlan XXX
switchport mode dot1q-tunnel
duplex full
speed 100
no mdix auto
l2protocol-tunnel cdp
l2protocol-tunnel stp
l2protocol-tunnel vtp
or post your current config to suggest.
BB
*** Rate All Helpful Responses ***
Highlighted
Unfortunately, these are Small Business Switches. I have some other commands.
On the old switch SF300 (worked)
interface fastethernet1
 description "Cust GR1 QinQ"
 switchport mode customer
 switchport customer vlan 1050
On SF350 port configuration:
interface FastEthernet1
 gvrp vlan-creation-forbid
 gvrp registration-forbid
 spanning-tree disable
 switchport access vlan none
 switchport trunk native vlan none
SW-GR1(config-if)#switchport mode
  general              generic port mode
  access               vlan unaware port
  trunk                vlan aware port
  customer             customer equipment port
  vlan-mapping         VLAN mapping modes
  private-vlan         private VLAN modes
I don't know what to do with it
SW-GR1(config-if)#switchport nni ethtype
  dot1q                TPID 0x8100
  dot1ad               TPID 0x88a8
  9100                 TPID 0x9100
  9200                 TPID 0x9200
Should I change something?
Highlighted
The mode customer and customer vlan work just fine on all our sg350.
Highlighted
Look at this thread may help you :
https://community.cisco.com/t5/small-business-switches/sg300-q-in-q/td-p/2887948
BB
