11-26-2018 12:37 AM - edited 11-26-2018 12:39 AM
In the network with SG300 switches I have a new SG350 switch.
How to configure qinq on it?
How should the Customer port be set to SG350? How to trunk between SG300 and SG350? Which Ethertype Tagging should be set?
On SG300 qinq works without problems.
11-26-2018 12:13 PM
have you tried below example :
interface FastEthernet x/x
switchport access vlan XXX
switchport mode dot1q-tunnel
duplex full
speed 100
no mdix auto
l2protocol-tunnel cdp
l2protocol-tunnel stp
l2protocol-tunnel vtp
or post your current config to suggest.
11-26-2018 02:44 PM
Unfortunately, these are Small Business Switches. I have some other commands.
On the old switch SF300 (worked)
interface fastethernet1 description "Cust GR1 QinQ" switchport mode customer switchport customer vlan 1050 !
On SF350 port configuration:
interface FastEthernet1 gvrp vlan-creation-forbid gvrp registration-forbid spanning-tree disable switchport mode customer switchport access vlan none switchport trunk native vlan none switchport customer vlan 1050 !
SW-GR1(config-if)#switchport mode general generic port mode access vlan unaware port trunk vlan aware port customer customer equipment port vlan-mapping VLAN mapping modes private-vlan private VLAN modes
I don't know what to do with it
SW-GR1(config-if)#switchport nni ethtype dot1q TPID 0x8100 dot1ad TPID 0x88a8 9100 TPID 0x9100 9200 TPID 0x9200
Should I change something?
12-13-2018 04:12 AM
The mode customer and customer vlan work just fine on all our sg350.
12-13-2018 04:34 AM
Look at this thread may help you :
https://community.cisco.com/t5/small-business-switches/sg300-q-in-q/td-p/2887948
