02-04-2013 03:55 AM
Does anyone know how to configure SNMP on the Cisco SG300 switches? I have the SG300-10P. I am not fully familiar with the new command line interface on this device, it was easy on the IOS but finding it a nightmare on this one.
I put the following command in but it didnt work.
snmp-server view Interfaces interfaces included
snmp-server community ACB123 ro 10.x.x.x view default
I tried to follow the guidelines on the cisco website but thats all Web interface based, i can only access the switch remotely via CLI.
02-04-2013 04:31 AM
Hi Rafik, here is the CLI guide for the SG300 series.
You will also need to enable SNMP management
config t
ip snmp server
-Tom
Please mark answered for helpful posts
02-04-2013 07:05 AM
I read throught this and made some changes, here is the new config and its still not working.
snmp-server view user-view snmpNotificationMIB included
snmp-server community ABC123 ro 10.x.x.x view default
snmp-server host 10.x.x.x traps version 1 ABC123
i also enabled SNMP management by typing into conf t -> snmp-server server
02-11-2013 06:19 PM
Hi Rafik, here is a basic snmp v1/v2 configuration
snmp-server server
snmp-server community test1234 rw view DefaultSuper
This is basically wide open to anyone who knows the password. This should be enough to get you started then you can tweak additional options as you go. Give this a test, see if you can do what you're trying to do then modify this sample to work for your security needs.
-Tom
05-24-2016 05:06 PM
snmp-server server is what was missing.
Thanks!
