How to save config through SNMP?
stasvolkhin
Hi!
I have Linksys SPS224.
I've learnt how to change some parameters through SNMP. But this changes are applying to running-config, and, when switch reboots, all loose.
How can I save this changed running-config to startup-config through SNMP?
Ivor Diedricks
Stanislav,
1) Download the MIB files
https://supportforums.cisco.com/docs/DOC-12105
2) Compile the MIB files on MIB browser e.g. MG-SOFT, SilverCreek. Make sure there is no compilation errors.
3) Configure SNMPv2 or SNMPv3 accordingly on SPS switch
4) Look for rlcopy.mib file.
The OID of rlcopy is 1.3.6.1.4(private).1(enterprise).3955(enterprisesx3955).89(rnd).87(rlCopy).
Using rlCopyTable(2), create an new entry on this particular table.
   a. rlCopyRowStatus: 4 (createAndgo)
   b. rlCopySourceLocation: 1  (local)
    c. rlCopySourceIpAddress: 0.0.0.0
    d. rlCopySourceUnitNumber: 1
    e. rlCopySourceFileName: (blank)
    f. rlCopySourceFileType: 2  (running config)
    g. rlCopyDestinationLocation: 1 (local)
    h. rlCopyDestinationIpAddress:  0.0.0.0
    i. rlCopyDestinationUnitNumber: 1
    j. rlCopyDestinationFileName:  (blank)
    l. rlCopyDestinationFileType: 3 (startup config)
By doing that, you should able to copy running config to startup config. Your configurations will not be lost between reboots.
Ivor
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
