how to take 2 different bandwidth on 1 port without VLan configuration ?
ashishpoyekar
Dear Sir,
I am having cisco SG 300 -28 switch and i have 2 bandwidth I want to connect bandwidth A to port on 25 & bandwidth B to port on 26 . Now port no 1 connect to desktop. If I dial pppoe user of bandwidth A so query will go to port no 25 & dial user of bandwidth B so query will go to port no 26. These both bandwidth will be separate. I don't want to create Vlan because I don't want to configure VLAN on customer devices. If 1 user is having bandwidth A & B both user name so he can able to connect with any username by just changing username & password.
Waiting for valuable reply
Ashish
ghostinthenet
Level 7
Level 7
Unfortunately, this isn't going to work for you. PPPoE's initial discovery uses a broadcast, so there's no way to determine which PPPoE access concentrator is going to reply unless you separate the two broadcast domains. I understand not wanting to go beyond the stock configuration on customer devices, but a two VLAN approach really is the easiest way to separate clients for the two PPPoE access concentrators.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
