CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
549
Beginner
Hybrid Stack SG350X 48p & SG350XG 2F10 crash
the 2F10 (unit2) crashed today. The upstream links to 2*SG550XG were dead till rebooting the whole stack.
Is this a know issue? Btw. the stack is for availability reasons....
FW: 2.3.5.63
2147483090 2018-May-31 05:38:06 Error %UDLD-E-MALFORMED_TLV: UDLD message from cached with illegal tlv. UDLD parsing error: errorUnsupportedVersion. mac 40a6e8ea765e
2147483197 2018-Jul-15 11:17:30 Alert %STCK SYSL-A-UNITMSG: UNIT ID 2,Msg: ***** END OF FATAL ERROR ***** ***** END OF FATAL ERROR *****
2147483198 2018-Jul-15 11:17:30 Alert %STCK SYSL-A-UNITMSG: UNIT ID 2,Msg:%SYSLOG-F-OSFATAL: caught segmentation fault exception at address 0xa0000020 signal-num = 11 (SIGSEGV) signal-code = 1 ( SEGV_MAPERR) reg[00] = 0xa0000022 reg[01] = 0x939e481b reg[02] = 0x0 reg[03] = 0x0 reg[04] = 0x9f0ff778 reg[05] = 0xa0000020 reg[06] = 0x939e481c reg[ 07] = 0x939e481b reg[08] = 0x939e459c reg[09] = 0x8 reg[10] = 0x3f FP = 0x3e8 IP = 0x1f69290 SP = 0xab5feb90 LR = 0x640cc4 PC = 0x640cbc CPSR = 0x60000 010 Fault Address = 0xa0000020 Trap no = 0xe Err Code = 0x815 Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: SYLG. Software Version: 2.3.5.63
2147483457 2018-Jul-14 15:29:19 Alert %STCK SYSL-A-UNITMSG: UNIT ID 1,Msg:/lib/libpthread.so.0(+0x6e64) [0xb6f02e64] ***** END OF FATAL ERROR ***** ***** END OF FATAL ERROR *****
2147483458 2018-Jul-14 15:29:19 Alert %STCK SYSL-A-UNITMSG: UNIT ID 1,Msg:%SYSLOG-F-OSFATAL: caught segmentation fault exception at address 0x1b3547c signal-num = 11 (SIGSEGV) signal-code = 2 (S EGV_ACCERR) reg[00] = 0x1 reg[01] = 0x20 reg[02] = 0x1b3547d reg[03] = 0xa reg[04] = 0x25f5094 reg[05] = 0x1b35444 reg[06] = 0x40 reg[07] = 0x0 reg[0 8] = 0x1 reg[09] = 0x0 reg[10] = 0x0 FP = 0x217ed58 IP = 0x20 SP = 0x535fea68 LR = 0x8225d4 PC = 0x822614 CPSR = 0x20000010 Fault Address = 0x1b3547c Trap no = 0xe Err Code = 0x81f Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: EVRX. Software Version: 2.3.5.63 (date Aug 20 2017 time 19:03:04)
1 REPLY 1
Highlighted
Re: Hybrid Stack SG350X 48p & SG350XG 2F10 crash
Based on this output I can suggest a couple of things:
1. You can see that UDLD threw an error message which means that it detected a unidirectional link. This could be caused by a bad cable/SFP so you can try to change those.
2. You are currently running firmware version 2.3.5. The latest firmware for the SG350xx is 2.4.0 so I can suggest to upgrade.
