CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
3315
mikew654321
Beginner
IEEE 802.3ad Connection Issues
I recently purchased a cisco 300 series 10 port managed switch and a synology 1511+ diskstation.  When trying to bond the 2 ethenet ports into link aggregation mode on the diskstation, i am recieveing an error that's "failing to establish IEEE 802.3ad connection".
From what i understand, the switch should allow this by defealt, but i am unable to determine why it's not allowing it.
If anyone could please help, it would be greatly apprechiated.  I am rather new to cisco gear.
Thanks!
Michael
2 REPLIES 2
derricklim66
Beginner
Have you solved your problem?
I have the same issues with you except I'm using SG200-18 with Synology 1512+.
Tom Watts
Advisor
Hello Mike Watts, can you provide the LAG configuration you've placed on the switch?
A lot of times the NAS will only support a LACP (not static LAG). However, if you can provide what kind of LAG the NAS will support will be most helpful.
From the command line here would be a sample input using LACP;
configure terminal
interface range fastethernet 3-4
channel-group 1 mode auto
From the command line here would be a sample input without using LACP;
configure terminal
channel-group 1 mode on
This will make a lag for port 3 and 4.
Please let me know if this helps at all.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
