11-27-2020 05:16 AM - edited 11-27-2020 05:17 AM
Hi Guys
I have one switch 3750 and two switches 2960. I started VTP and DHCP. But when I connect the computers to the switches after they get a proper IP from DHCP, they can not ping each other. Whether they are in the same VLan or devices have different VLans. In Packet Tracer, everything is correct and the devices ping each other. But this choice does not fall on the physical switch. I put the switches config file. Please tell if there is a mistake and if there is a way to improve. And what can I do to make VLans have access to each other and fix this problem?
3750 :
enable configure terminal hostname SW-Core ip default-gateway 10.10.10.1 ip domain-name F13 vtp mode server vtp domain F13 vtp version 2 vtp pruning enable secret Hadi@123 line vty 0 15 password Hadi@123 login exit line console 0 password Hadi@123 login exit VLan 10 name Core exit VLan 31 name F3N exit VLan 32 name F3S exit interface vlan 10 ip address 10.10.10.1 255.255.255.0 no shutdown exit interface vlan 31 ip address 10.10.31.1 255.255.255.0 no shutdown exit interface vlan 32 ip address 10.10.32.1 255.255.255.0 no shutdown exit ip routing interface range gigabitEthernet 1/0/1-6 switchport trunk encapsulation dot1q switchport mode trunk switchport trunk allowed vlan 1-99 no shutdown exit interface range gigabitEthernet 1/0/7-12 switchport mode access switchport access vlan 10 no shutdown exit interface range gigabitEthernet 1/0/13-24 shutdown exit ip dhcp pool Core network 10.10.10.0 255.255.255.0 default-router 10.10.10.1 dns-server 10.10.10.2 lease 21 exit ip dhcp pool F3N network 10.10.31.0 255.255.255.0 default-router 10.10.31.1 dns-server 10.10.10.2 lease 21 exit ip dhcp pool F3S network 10.10.32.0 255.255.255.0 default-router 10.10.32.1 dns-server 10.10.10.2 lease 21 exit ip dhcp excluded-address 10.10.10.1 10.10.10.10 ip dhcp excluded-address 10.10.31.1 10.10.31.10 ip dhcp excluded-address 10.10.32.1 10.10.32.10 exit exit write
One of the 2960 switches :
enable configure terminal hostname SW-F3N vtp mode client vtp domain F13 enable secret Hadi@123 line vty 0 15 password Hadi@123 login exit line console 0 password Hadi@123 login exit interface gigabitEthernet 0/24 switchport mode trunk no shutdown exit interface range gigabitEthernet 0/21-23 shutdown exit interface range gigabitEthernet 0/1-20 switchport mode access switchport access vlan 31 no shutdown exit exit write
Solved! Go to Solution.
11-28-2020 11:21 PM
Can you post both the devices below information :
show vtp status
show vlan
other observation based on your input.
- But even in VLAN 10, which is on the 3750 switch, when two devices receive IP from DHCP, they still can not ping each other.
BB - if the Device to device has communication (i am guessing based on above statement) - Windows FW is the issue, disable Windows FW and test.
Gateway of last resort is not set
BB - is this Device no outgoing internet or is this just inside the office network.
high level my understand is - you have Core switch which has no connection anywhere to go to the internet, all the SVI VLAN configured and they able to communicate each other ? and you have added Layer 2 switch - but end device not able to communicate with the devices connected in the Core switch.
11-27-2020 05:38 AM
If you end Access switch device connected to VLAN 31, they should be able to get access other vlan since you already enabled in Trunk
worth look at 2960 switch - is the VLAN populated and spanning tree available - make sure always use VTP v2
Are you able to ping other Gateways ? from the device ?
can you post show ip route from the main switch ?
11-28-2020 10:36 PM
Thank you for your response
- VTP version 2 is enabled
VTP Version : 2
Configuration Revision : 12
Maximum VLANs supported locally : 1005
Number of existing VLANs : 12
VTP Operating Mode : Server
VTP Domain Name : F13
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0x52 0xDD 0x64 0x03 0x7F 0x97 0x90 0x1E
Configuration last modified by 10.10.10.1 at 3-1-93 00:07:20
Local updater ID is 0.0.0.0 (no valid interface found)
- Gateway and even other VLANs can be pinged.
SW-Core# show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
10.0.0.0/24 is subnetted, 7 subnets
C 10.10.10.0 is directly connected, Vlan10
C 10.10.31.0 is directly connected, Vlan31
C 10.10.32.0 is directly connected, Vlan32
C 10.10.41.0 is directly connected, Vlan41
C 10.10.42.0 is directly connected, Vlan42
C 10.10.51.0 is directly connected, Vlan51
C 10.10.52.0 is directly connected, Vlan52
11-28-2020 11:21 PM
show vtp status
show vlan
