Intelligent PoE on SD208P?
hhansen
Small Question - wondering if the PoE is intelligent in terms of providing the power needed for the IP-device plugged into the port..if this is done automatically or not?
chrcoope
This depends on the PoE but the simple answer is yes. SD208P is 802.3af compliant.
http://en.wikipedia.org/wiki/Power_over_Ethernet
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10007/ps10020/data_sheet_c78-530613.pdf
Hope this helps.
