07-30-2012 10:43 AM
Here is my proposed configuration, tell me if I am missing something.
I have the following hypethetical subnetting scheme
2 subnets, 2 vlans.
lets say for argument that subnet 1 is on network 172.16.0.0
and subnet 2 is on netowkr 172.16.32.0
lets say of have 2 vlans
VLAN 10
VLAN 20
I have a router port IP assigned of 172.16.0.1
I have 2 DHCP pools that match the 2 subnets Im using
172.16.0.1 - 172.16.31.254 excluding 172.16.0.1
default gateway 172.16.0.1
and
172.16.32.1 - 172.16.63.254
here is the issue.
both DHCP pools use the same default gateway as the switches can only be set up on the network to come off of a single port on the router
Now lets assume that all switches are Trunked and on the same VTP domain, and that all ports are set to VLAN 1.
Now some 5 or 6 switches down the line I have all of the ports assigned to VLAN 2,
This is wherer the problem arises
How will the router know Which DHCP pool to assign to wich VLAN. I want all hosts on this switch to be assigned to subnet 172.16.32.0. VLAN 2
and all hosts on all other switches to be assigned 172.16.0.0 on VLAN 1
How is this done?
What am I missing?
07-30-2012 10:50 AM
Hi Drew,
The small business switches do not support VTP.
If using a L3 small business switch, you would enable DHCP option 82. specify the DHCP relay and then do add route on the DHCP server.
-Tom
07-30-2012 01:00 PM
thanks for reply.
so if the small business switches dont support vtp, i can manually configure vlans on each switch
i would like to have dhcp comming from 1 central location , that being the router.
what is option 82 and is that set on the switch or router?
07-30-2012 01:06 PM
The option 82 can be set on the switch. If your router is the DHCP server, it shouldn't require option 82 as long as the trunk/tags are understood.
-Tom
