CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1351
Highlighted
Beginner
LAG between SG300 and Windows server on VMware ESXi 5.5
I'm trying to setting up a LAG of 2 x 1GB between a Windows 2012 server on VMware 5.5 and a SG300-52 switch, but without any success till now.
The SG300 is configured as follow :
config-file-header
SG300-52
v1.4.0.88 / R800_NIK_1_4_194_194
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
port jumbo-frame
vlan database
vlan 10,20,30,40,50,60,70,99
exit
voice vlan id 40
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
port-channel load-balance src-dst-mac-ip
ip dhcp pool network DHCP-VLAN1
address low 192.168.2.120 high 192.168.2.139 255.255.255.0
default-router 192.168.2.1
exit
ip dhcp pool network DHCP-Internal
address low 172.16.0.40 high 172.16.0.79 255.255.255.0
default-router 172.16.0.1
exit
ip dhcp pool network DHCP-Management
address low 10.0.0.120 high 10.0.0.139 255.255.255.0
default-router 10.0.0.1
exit
ip dhcp pool network DHCP-Phone
address low 10.0.2.80 high 10.0.2.99 255.255.255.0
default-router 10.0.2.1
exit
ip dhcp pool network DHCP-Pro
address low 10.0.1.140 high 10.0.1.199 255.255.255.0
default-router 10.0.1.1
exit
ip dhcp relay address 10.0.0.60
ip dhcp relay enable
ip dhcp information option
bonjour interface range vlan 1,10,20,30
qos trust cos
hostname SG300-52
username cisco password encrypted c464af817287343305cbd6493c593885695df531 privilege 15
ip ssh server
ip telnet server
interface vlan 1
 ip address 192.168.2.1 255.255.255.0
 no ip address dhcp
interface vlan 10
 name Management
 ip address 10.0.0.1 255.255.255.0
interface vlan 20
 name Pro
 ip address 10.0.1.1 255.255.255.0
interface vlan 30
 name Internal
 ip address 172.16.0.1 255.255.255.0
interface vlan 40
 name Phone
 ip address 10.0.2.1 255.255.255.0
interface vlan 50
 name TV
interface vlan 60
 name "Exchange DB Replication"
 ip address 10.0.100.1 255.255.255.0
interface vlan 70
 name Test
interface vlan 99
 name WAN
 ip address 192.168.0.2 255.255.255.224
interface gigabitethernet1
 switchport mode access
 switchport access vlan 10
interface gigabitethernet2
 switchport trunk allowed vlan add 10,30,40
 no cdp enable
interface gigabitethernet3
 switchport trunk allowed vlan add 20
interface gigabitethernet4
 switchport access vlan 60
interface gigabitethernet5
interface gigabitethernet6
 switchport access vlan 20
interface gigabitethernet7
interface gigabitethernet8
 switchport access vlan 30
interface gigabitethernet9
interface gigabitethernet25
interface gigabitethernet26
 channel-group 2 mode on
interface gigabitethernet27
interface gigabitethernet28
 switchport trunk native vlan 60
interface gigabitethernet29
interface gigabitethernet30
interface gigabitethernet32
 qos cos 5
interface gigabitethernet45
 spanning-tree link-type point-to-point
 switchport access vlan 50
 macro description switch
 !next command is internal.
 macro auto smartport dynamic_type unknown
interface gigabitethernet46
interface gigabitethernet47
interface gigabitethernet48
interface gigabitethernet49
 switchport access vlan 99
interface gigabitethernet51
 switchport trunk allowed vlan add 10,20,30,40,50,60,70,99
 macro auto smartport dynamic_type switch
interface Port-channel2
 description HBAIP-VM2
exit
ip default-gateway 192.168.0.1
ip route 10.0.0.0 /24 192.168.0.1
ip route 10.0.1.0 /24 192.168.0.1
ip route 10.0.2.0 /24 192.168.0.1
ip route 172.16.0.0 /24 192.168.0.1
  • GE26 & GE27 have been added in LAG2
  • VLAN 1UP, 10T, 20T, 30T & 40T have joined the LAG
  • In VMware, a vswitch has been created, using the 2 NIC connected to the LAG; and a Virtual Machine Port Group has been created for each VLAN member of the LAG
  • In Windows 2012, the 4 Network adapters have been added (1 for each VLAN), but they cannot ping their gayeway
  • However, the interfaces receives correctly thei IP addresses (and options) from the DHCP server, via the DHCP relay of the SG300
I also following the configuration described in this link (http://it-erate.com/setting-lag-vmware-esxi-5-cisco-sg300/) but without any success.
Do you have any idea ?
Thanks in advance for your help.
1 REPLY 1
Highlighted
Beginner
Please make sure the load
Please make sure the load balance mode in VMware is Route based on IP Hash.
The default value is virtual switch port ID, which cannot work together with port-channel in upstream switch, as explained in:
http://www.vmware.com/files/pdf/virtual_networking_concepts.pdf
"Note: If you select either srcPortID or srcMAC hash, you should
not configure the physical switch ports as any type of team or
bonded group."
