CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
743
Highlighted
Beginner
LAG , how to?
I have two serie 300 switches with 4 vlans created. I normally have one connection between two switches and configured as trunk mode with vlans added to that trunk.
Now i want to have a new connection so it will have two links between each other and i want to have a LAG so I will have 2 GB communication.
But It give me error  because those port are associated to vlans. What should i do to create that LAG, add two ports and allow vlans to communicate between switches?
thanks a lot and sorry for my ignorance.
Everyone's tags (3)
3 REPLIES 3
Participant
LAG , how to?
Hello Angel,
You will want to set the ports you plan on connecting in the LAG to the same state. (same vlans same port type) Once this is done, you will do the following-
Port Management > Link Aggregation > LAG Management
Select one of the available LAGs and then hit edit
Select ports from the left side and add them to the right
Now repeat these steps on the other switch.
Once you are done they ports will be joined as one LAG.
Highlighted
Beginner
LAG , how to?
Robert, Thanks for your reply.
After I have the LAG configure with the ports, how should I set that LAG to allowd vlans i want? like a trunk port where I set vlan allowed.
thanks.
Highlighted
Participant
LAG , how to?
Yes, you will treat the new LAG as if it was just one port. You can change the LAG to trunk and add vlans just the same way.
