CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
731
Hristo Todorov
Beginner
linksys SRW208G does not run after Factory Defaults...?
I had to Restore the switch to Factory Default...now when i connect to PC via ethernet I am not able to access it.
I have HyperTerminal...I am able to connect to the switch- I tried changing the IP address but still not able to access via WEB
Please help
4 REPLIES 4
Tom Watts
Advisor
Hi Chris, can you verify the HTTP access is enabled when you're using the console access?
Do you have a link light when you connect your computer to the RJ45 connection?
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Yes I have both lights on.
Okay, is the switch plugged in to your network?
-Tom
Sorry for the late reply, Tom...
No the switch is plugged only in my computer...
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
