Hi, I had an interesting issue with some catalyst switches:
The models are a 2960 (24x10/100/1000 + PoE ports) and a 3560 (24x10/100/1000).
Suddenly, several static entries apeared in the MAC address table, linked to Gigabit Ethernet Ports, the MACs were from real PCs working in the room.
As far as I know (but I must be wrong in this point) this should be possible only through manual configuration "Switch (config)# mac address-table static...". However, after typing either "show running-config" or "show startup-config" there is not a single line adding static MAC addresses to the switch.
This was causing the problem that some laptops were not able to receive traffic, since their MAC addresses were statically learned on other ports.
The solution (so far) was issuing the "no mac address-table static..." command so it is all god by now.
Question: What could be another way for the switch to learn static MAC addresses without having them in any config file (run or start)? May be through a flash or NVRAM file such as the vlan.dat? How to prevent this from happening again in the future?
Thanks in advanced.
