Management VLAN on SG200 Switch
Romeo Sulzer
We have the following setup:
  • SG-300-28 Switch in Layer 3 Mode
  • SG-200-08P Switches in every office room
VLANS:
100 = Data
200 = Management
On the SG-200 I set the Management VLAN to 200, this has the effect that one of the ports needs to be an untagged member of the management VLAN 200.  However, I need all of the ports to be an untagged member of the data VLAN and I also don't want that the management LAN is accessible from the offices.  What options do I have in this case?
Thank you very much for your input.
Romeo
Tom Watts
You can tag the management VLAN as 200.
So long as the SG300 has a vlan 200 tagged on its port and the sg200 has vlan 200 tagged on a port it should be perfectly fine.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom
Thanks for your reply.  If I remember correctly the SG200's GUI requires that the management VLAN is untagged on at least one port.  Currently I don't have a SG200 lying around to test this.  I will check again the next time I am on-site.
Kind regards,
Romeo
Hi Romeo, even if this is true, just assign it to a random port then shut that port down.
I have a sg200 running at my house I can double check as well.
Hi Tom,
Thanks for your advice.  I will check again and if the GUI really requires me to assign the mgt. vlan untagged to at least one port I will do as you have suggested.  Thanks a lot!
Kind regards,
Romeo
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
